D4 Upgrade Advice
Solved by Queen Chrysalis,
7 minutes ago, ANobleSteed said:Cheers. My main goal is upgrading the GPU currently, so i'll keep looking at options with that.
No worries. If you go with a GPU that's using more than like 200w, you might want to look into a bigger PSU. I'd say yours is fine with like a 6600xt or maybe a 6700xt (or 3070), but with any more power draw than that, you'll probably want a more pwoerful PSU.
Another little tidbit, the 5700xt is a steal on eBay right now for a quite powerful GPU. It's punching about the same as a 6600 for quite a bit less in most places. Just uses a bit more power, but it'd be fine on a cx600.
