USB getting disconnected and reconnected while playing heavy games. All my usb ports just turn off and then after seconds connect back up. Only while playing like Warzone 2 or Cyberpunk.
I bought new motherboard z690 Z690 GAMING X DDR4  rev 1.  Any ideas on how to fix
RTX 3080
I5 13600KF
Z690 GAMING X DDR4
https://linustechtips.com/topic/1502557-usb-reconnecting-issue/
I followed this topic because my gamepad also had exactly same issue despite being on AMD platform.
Things I found that did NOT solve the issue:
1. Uninstall then reinstall chipset driver
2. New gamepad
3. Change the USB port, from front then to 3 different rear USB ports
Fix that only works 50/50 the time. Plug the gamepad, then put PC on sleep. Wake up and the play the game.
Windows 10
Ryzen 5 3500x
Gigabyte B450M
RX 5700 XT
FSP HV 500 watt PSU
Gamepad gladius GX-1 (I have 2 on hand).
https://linustechtips.com/topic/1502557-usb-reconnecting-issue/#findComment-15905739
2. New gamepad
Windows 10
Ryzen 5 3500x
Gigabyte B450M
RX 5700 XT
FSP HV 500 watt PSU
Thanks for the tip
Problem is that I don't use a gamepad.
I just play normally and suddenly all my peripherals flash and the keyboard/mouse turns off, I can also hear loud white noise in earphones.
https://linustechtips.com/topic/1502557-usb-reconnecting-issue/#findComment-15905759
