Healthy Computer Suddenly Doesn't Power On
Go to solution Solved by Trinity-W,
47 minutes ago, Coolman5401 said:
My PC was working perfectly fine, I took out the power supply to test another computer with it, put it back in my main computer. Now when I press the power button it turns on for a few seconds and then turns off for a few seconds, and repeats that cycle indefinitely. Never reaches bios, no signal to monitor, no beeps or error lights.
My specs:
Motherboard: ASUS PRIME B360M-A (300 Series) Intel LGA-1151
power supply: EVGA 500 W1 80+ White 500W
Ram: Patriot Memory Signature Lne DDR4 4GB
Graphics Card: Nvidia Geforce Gtx 1050ti
pls help 😞 ty
Try clear CMOS. Try remounting CPU. It could now be faulty your PSU. Might need a new PSU.
My specs:
pls help ): ty
https://linustechtips.com/topic/1502501-healthy-computer-suddenly-doesnt-power-on/
My specs:
pls help 😞 ty
Bit of a tech guy, converted to PC's when consoles did not entertain me enough, the last console being an Xbox, was fun with Halo multi-play though. But  the want to discover, to test, to learn more about computers drove me to levels I had never known...
Some GPU's I have had, 8800GTS 384MB, 7800GT, GEFORCE 4 MX440, 250GTS,  770 GTX, 1650 GTX, RTX 3050 Plus many other GPU's over the years...
The respect I have for LMG is massive like a black hole, sucking in all the knowledge, I watch their awesome video's, their knowledge is like that of a God. Seriously some say they are number 1 in the whole wide world. LMG is like the INTEL fabrication plant. Beaming with technology goodness...
1 hour ago, Coolman5401 said:
Cleared CMOS, now it stays on but no video output from motherboard or graphics card.
check all plugs, sounds like your CPU power isn't connected.
it's a small PSU.. wattage wise.. it is possible to "test" it on another system that trips the over draw protection and screws it up. when you plug it into your own system again.
I'd check all cables. Run it with just memory, CPU, remount CPU, repaste it.
Took everything off the motherboard then reassembled it and now it's back to working, thank you!
Great one man! Buzzing for you, it's great when you get a computer booting up and working after hours, days of messing around, a good buzz. 🙂
