Hey it's my first time to have a PC built and i'm not sure if the parts i chose are the best for my money's worth. This PC will be used for gaming and architectural rendering.
I currently have:
23" ASUS VX239 LED SLIM IPS
CM Devastator mouse and keyboard
Corsair Vengeance mm200 mouse pad
Corsair Vengeance 2100 7.1 Gaming headset
What I need to buy:
INTEL CORE i7 4770K (3.50 Ghz, 8MB CACHE, LGA1150)
15450
PCNETMILES
MSI Z87-G45 GAMING Z87 / DDR3 / MC4 / SB CINEMA
8150
PC QUARTERS
G.Skill Ripjaws X 16GB 8x2 DDR3 1866 CL9
7600
PCNETMILES
WDigital Caviar Blue 1TB SATA3 7200rpm
2390
PC HUB
PALIT GTX760 4GB JETSTREAM
13400
PC QUARTERS
ASUS DRW-24F1ST 24X OEM SATA
900
PC EXPRESS
COOLER MASTER SCOUT II
4400
PC EXPRESS
COOLER MASTER Silent PRO M2 720W 80+ Modular
3900
PC QUARTERS
COOLER MASTER Hyper 212X
1650
PC EXPRESS
NZXT Sentry 2 Bay Fan Controller
1330
PC HUB
COOLER MASTER Sickle Flow A1 Blue
350 (x4)
PC HUB
ASUS Xonar DGX 5.1 Gaming Series PCIE
1590x
PC HUB
Budget: 60,000 - 70, 000 PHP
Preferences:
Nvidia Graphics card
CM Storm Scout II
More RAM the better i guess if it helps with rendering speed?
Good cooling system (not water cooled)
Blue LED
Here are the links to the price lists of each of the stores: (Currency - Philippines pesos)
http://www.tipidpc.com/useritems.php?username=PC_Quarters
http://www.tipidpc.com/useritems.php?username=pcnetmiles
http://www.tipidpc.com/useritems.php?username=PCHub
http://pcx.com.ph/pcx-pricelist/
https://linustechtips.com/topic/150116-help-pc-build-advice/
Use pcpartpicker.com
And get a 780, and get 16 GB RAM, otherwise you're golden.
- "some salty pretzel bun fanboy" ~ @helping, 2014
- "Oh shit, watch out guys, we got a hopscotch bassass here..." ~ @vinyldash303
- "Yes the 8990 is more fater than the 4820K and as you can see this specific Video card comes with 6GB" ~ Alienware 2014
https://linustechtips.com/topic/150116-help-pc-build-advice/#findComment-2006523
Are you using CUDA to render, or are you rendering off the CPU? It really matters, as if you are using CUDA a 770 would be better than an i7, but if you are using the CPU it would not matter if you got a GT610 or a 295x2, it would still have the same render time.
Also, generally you do not need a sound card. Very few of them are any better than the integrated unit, unless it does not work or you need 2 SPUs for some reason.
Desktop <dead?>
P8P67-WS/Z77 Extreme4/H61DE-S3. 4x4 Samsung 1600MHz/1x8GB Gskill 1866MHzC9. 750W OCZ ZT/750w Corsair CX. GTX480/Sapphire HD7950 1.05GHz (OC). Adata SP600 256GB x2/SSG 830 128GB/1TB Hatachi Deskstar/3TB Seagate. Windows XP/7Pro, Windows 10 on Test drive. FreeBSD and Fedora on liveboot USB3 drives.
Laptop <Works Beyond Spec>
HP-DM3. Pentium U5400. 2x4GB DDR3 1600MHz (Samsung iirc). Intel HD. 512GB SSD. 8TB USB drive (Western Digital). Coil Wine!!!!!! (Is that a spec?).
https://linustechtips.com/topic/150116-help-pc-build-advice/#findComment-2006530
What's CUDA? The programs i'll be using are Sketchup 14, Vray, Lumion, 3DS Max, Vray, Artlantis, etc. But of course aside from that i want a pc thats good for gaming.
https://linustechtips.com/topic/150116-help-pc-build-advice/#findComment-2006723
Don't get the 4GB 760. Get a 770 or 780 if that is in the budget. If not then get the regular 2GB 760 the double VRAM has no real use.
Owner of a top of the line 13" MacBook Pro with Retina Display (Dual Boot OS X El Capitan & Win 10):
Core i7-4558U @ 3.2GHz II Intel Iris @ 1200MHz II 1TB Apple/Samsung SSD II 16 GB RAM @ 1600MHz
https://linustechtips.com/topic/150116-help-pc-build-advice/#findComment-2006732
CUDA is the Nvidia core since the GT(s)(x) 8000 generation. Sketchup will depend on the plugin you choose to use. Vray will not use the GPU to render unless they amended that in a later version than I use. Lumion seems to allow GPU rendering. 3ds max does use the GPU to render.
Of the programs you stated, you would probably get better performance from a more powerful GPU than you would from a better CPU. Just go for a 4670k plus a 770/780 if you can afford it. You can also look into the Xeon E3-1240/1245 also, they are the same thing as a 4770 without the extra $100 cost in most countries.
Edit: Gaming does not matter that much. Build for the rendering and it will game.
Desktop <dead?>
https://linustechtips.com/topic/150116-help-pc-build-advice/#findComment-2006915
