Hey guys, so I downloaded a couple of weeks ago that software, I thought it worked but today I tried it with a movie that was playing on the background. I simply putted every settings max, sounded not different at all, so I deactivated the whole thing, sound was still the same.
I do think I'm not hearing a single difference and that it's not normal, what is the problem here ?
Intel i5 4670_MSI Z87-G43_2x4Gb DDR Kingston HyperX Beast_Sapphire R9 290 Tri-X OC_Corsair Carbide 300R Window_120Gb SSD Samsung Evo_1Tb WD Caviar Black_Corsair CX750 w_BenQ XL2720T_CoolerMaster Hyper 212 Evo_Razer Blackwidow 2013_Razer Deathadder Black_ATH-AD700 Headphones_ATR2500 Cardoid Microphone
https://linustechtips.com/topic/150063-sound-blaster-cinema/
Most audio software like that are gimmicks.
idk ive seen many reviews of people saying it was really nice, meaning that they can still hear a difference, I mean I hear absolutely nothing changing when I'm putting bass boost to the max, that must not be normal.
https://linustechtips.com/topic/150063-sound-blaster-cinema/#findComment-2009394
You probably didn't have it setup correctly, or it wasn't working right on your computer. I'm not sure what this software is or does, but if it's just an EQ you can get plenty of other software that does it quite well.
https://linustechtips.com/topic/150063-sound-blaster-cinema/#findComment-2009398
