I am Planning on buying a Geforce GTX 780 but cannot afford one at the moment.
I got as hand-me-down card when I completed my build(Geforce GT 240) and now my father got himself a better graphics card so I wanted to use his (another hand-me-down) The Raeon HD 6770.
After removing all the Invidia drivers and putting in the Graphics card I was not able to connect my monitor via the graphics card, only through the mother board.
When I connect it to the card the monitor says "No signal".
I installed the drivers that came with the card and looked online for the updates.
My build:
CPU: i5-4670k
RAM: G.Skill Ripjaws x Series 16GB (2x8GB)
SSDSamsung Electronics 840 EVO-Series 250GB
Power SupplyCorsair CX Series 750 Watt ATX/EPS Modular 80 PLUS Bronze ATX12V/EPS12V 744 Power Supply CX750M
Monitor Resolution: 1920x1080
https://linustechtips.com/topic/150024-what-am-i-doing-wrong/
what motherboard is it?
Intel i7-7770K | Asus Maximus X Hero  | EVGA GTX980 SuperClocked | 16GB Memory| Samsung 960 EVO M.2 | Corsair RM 750W | Dell 27" S2716DG main display | Dual Dell ST2320L 23" Secondary displays | Windows 10
Logitech G710+ Keyboard | Logitech G502 mouse | Kingston HyperX Cloud headset | Corsair H100i
https://linustechtips.com/topic/150024-what-am-i-doing-wrong/#findComment-2005253
the graphics card maybe be broken. usually in this case.
have you made sure you have the power connector plugged tight into the card? or a different 6 pin maybe? clean the pcie slot from any dust accumulation etc. plugged in motherboard power cables properly (all 24pin& 4/8pins)
ninja learns fast :ph34r:
Details separate people.
https://linustechtips.com/topic/150024-what-am-i-doing-wrong/#findComment-2005273
Could you install GPU-Z and check if the graphics card is detected there? If it is maybe there is a setting in your UEFI to specify which graphics option to prefer.
Main PC:
CPU: 3700x Motherboard: X570  RAM: 2x16GB 3600Mhz GPU: RTX 3080 Case: Corsair 4000D Air Storage: 1TB NVMe 2x250GB SSD RAID 0 2TB HDD PSU: 1000W Gold Display: Acer X34A Peripherals: Corsair K95 RGB Red, Razer Viper Ultimate
Laptop:
Lenovo Thinkbook 13s  CPU: i5-8265U RAM: 8GB  Storage: 256GB SSD Display: Dell P2414H Peripherals: CMStorm Quickfire TK Brown, Razer Atheris
Audio:
Beyerdynamic DT770 Pro 250 Ohm, FiiO E11, Stoner Acoustics UD100, Shure SE-215, Logitech Z906, Mission 731, Altec Lansing ADA-885, xDuoo UA-05, AKG K7XX,FiiO X3, FiiO K3
https://linustechtips.com/topic/150024-what-am-i-doing-wrong/#findComment-2005283
Wait, wouldn't the IGP of a 4670k be a bit better than a GT 240? I'm not entirely certain on that, but I thought I remember seeing benchmarks supporting that theory.
Anyway, I remember having a total pain with my Radeon 6670 in my other computer. The problem was that it wasn't firmly secured into the socket. Try to see if it feels looser than the GT 240 did or not. If it feels looser, then it could just simply be that.
Previously Trogdor8freebird
5800x | Asus x570 Pro Wifi (barely enough for 64GB apparently given it's 2133 and still crashes sometimes) | 64GB DDR4 | 3070 Ti 8GB | Love that whole weeb shit
https://linustechtips.com/topic/150024-what-am-i-doing-wrong/#findComment-2005313
GUYS!! he said he plugged the monitor through the motherboard...he's using the IGP if there's one...you HAVE to connect the monitor to the graphics card in order to get a signal from it...if your monitor does not have the correct connection type you may need an adapter...something like this :
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
https://linustechtips.com/topic/150024-what-am-i-doing-wrong/#findComment-2005882
What I said was that it did not work plugged into the Graphics Card but it did work plugged into the Motherboard.
I am sure the Graphics card works since it works fine on my father's computer.
MotherboardGigabyte LGA 1150 Intel Z87 HDMI/DVI-D/D-Sub UEFI Dual BIOS ATX Motherboard GA-Z87-DS3H
https://linustechtips.com/topic/150024-what-am-i-doing-wrong/#findComment-2006127
I will look into it thank you.
https://linustechtips.com/topic/150024-what-am-i-doing-wrong/#findComment-2006135
Make sure the card is firmly in place in the slot, and the PCI-E power connector (if there is one) is seated nicely as well.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/150024-what-am-i-doing-wrong/#findComment-2006155
