Does ram speed matter?
Solved by TetraSky,
Not really. It wouldn't be noticeable at the naked eye and at best you'd get a few extra fps in some games.
Even less if the higher speed RAM also has a higher CAS latency.
There's a point of diminishing return and for DDR4, that's around 3200.
If you already have 3200 RAM, there's not much point wasting money going to 3600. Save up for your next big upgrade to DDR5 on the newer platforms.
