Dual monitor arm problem
Solved by VIVO-US,
The inner arm section can be swapped from one side to the other, making one arm extra long and the other short. All you have to do is remove the large bolt from the top of each hinge, and we do include the correct 5mm Allen wrench with it. The joints can also be tightened to prevent the arms from swinging too easily. The minimum distance from the wall is about 7.5cm (as long as you can also get the pole to the wall). We hope the setup all comes together well for you!
