First upcoming PC build
6 minutes ago, svorcneger said:So I took in consideration what @Extremos, @filpo and @brob told about CPU and cooling and decided to go with i7-19700K ( K version mainly because of integrated graphics) and ak620. I kind of knew about 13900k heat problems but if it needs a really beefy cooler, then I might as well downgrade the cpu. As for case, I choose
BitFenix NOVA MESH SE TG ATX Mid Tower since it looked like it will have airflow I will need.. I also downgraded power supply to Corsair RM750e 750 W 80+ Gold since I won't be needing more than 700W ( correct me if I'm wrong and should I consider a more powerful power supply?). Also thanks to @SorryClaire I found where to check for cheaper prices. So my main concern left is power supply and what I should have in consideration while choosing one.
go for a name brand. Don't go for a 'GameMax'. Also don't underspend. the one @SorryClaireput in their latest build is a very good one for the price
