Replacement Hard Drive issues
Solved by matt0725,
the replacement drive may not be appearing as your D drive in windows. If you open file explorer and go to "This PC" you will see all the drives you have connected, in your case at least 2, a C drive, and something else. If your replacement drive isnt the D drive, you can change it so windows can follow the correct path again.
EDIT: @Needfuldoer beat me to it with a link and everything, damn lol
