Power brick replacement
Go to solution Solved by Poinkachu,
16 minutes ago, daveyjones98 said:
Hello guys i have a bunch of Vadio cameras that have burned out but cannot find a replacement? can you guys help me find a replacement power brick for these attached pictures? i dont know if its the company that has stopped making them or if they have superseded the part numbers thanks in advance thanks in advance
Looks like standard power brick with 5.5mm x 2.5mm DC barrel jack to me.
So..., Get a 18 volt power brick that can supply at the very least 2,75 Amps. Preferably one with decent build quality.
Example of 18v/3A power brick :
Fixed voltage version :
https://www.amazon.com/UpBright-Global-18V-DC-Adapter/dp/B01LL0C8LG/ref=sr_1_3?crid=NIO2QFBT1Q6&keywords=power+brick+18v+3a&qid=1680713460&sprefix=power+brick+18v+3%2Caps%2C304&sr=8-3
Variable Voltage version :
https://www.amazon.com/SHNITPWR-Adjustable-Universal-100V-240V-3-5x1-35mm/dp/B08BL4QMGM/ref=sr_1_22?crid=2H268W7SCJ183&keywords=power%2Bbrick%2B18v&qid=1680713387&sprefix=power%2Bbrick%2B18v%2Caps%2C372&sr=8-22&th=1
5.5mm x 2.5mm DC Barrel jack measurement
https://linustechtips.com/topic/1498929-power-brick-replacement/
Refresh before you reply
So..., Get any 18 volt power brick that can supply at the very least 2,75 Amps.
im sorry i dont even understand enough about what you said to even find one on amazon is there a link you can help me with?
I updated my post with link of an example.
Basically just use these keyword : 18v power brick  or  18v power adapter
then make sure it's output voltage is 18v (volt) , and output current is at least 2.75A (Amps, Ampere)  . Either by checking specification section, or asking the seller.
As for the connector (the one you are holding on your first pic).
From that pic it looks like a 5.5mm x 2.5mm DC barrel jack to me.
There is various sizes of DC barrel jack, hence why I updated my first post with a measurement of a 5.5 x 2.5 DC jack, in case you want to measure to be really sure or something.
