Which Ryzen CPU is less bottleneck and best for RTX 3070 running on 1080p 144hz?
I currently using Ryzen 5 3600 with my RTX 3070, 2 x 8 gb 2133mhz ram, and 2 x 1080p 144hz monitor.
Then, I found that my fps is not that high (not at 144hz with high graphics) while gaming, and was considering upgrade my CPU, is this a wise move?
If it is, which Ryzen CPU most suite my set up? Any suggestions?
The ryzen 5 5600(X) should be a good fit. I think the 5800x3d or ryzen 7000 are to expensive and not worth it for a 3070.
Then, I found that my fps is not that high while gaming, and was considering upgrade my CPU, is this a wise move?
Yes a 3600 is a big bottleneck for a 3070. I would strongly recommend upgrading to a 5800x. It has 8 cores and 16 threads, providing amazing gaming results and a perfect fit for the 3070.
Have you tried turning it off and on again? Maybe Restart it?
If my comment solves your problem mark it so.
Take everything I say with a grain of salt. I could be just about wrong as I am right.
Main RIG
13600K (Undervolted) +MSI Z690 Edge Wi-Fi+ Team Elite 32gb RAM (3200) +Noctua Nhd-15 Chromax Black+ Intel 670p 1TB SSD+ Intel Arc A770+ Corsair Crystal 465x case+ EVGA SuperNOVA 650W PSU.+ ASUS VP222 Gaming Monitor
Laptop for School: Surface go 2 (sucks ass)
Laptop for tinkering: Dell Inspirion 3358
Audio: Apple Airpods Pro (1st Gen)
(Apple_reigns_ supreme_ forever_ and_ ever)
(I am 14 years old and don't know shit about fucking shit.)
Everyone must suffer one of two Pains: The pain of Discipline or the pain of regret and disappointment.
-Jim Rohn
My brother recently got my 5800x3D and 3600MHz kit of RAM to replace his R5 3600 and 3200MHz kit (mind you with an RTX 3070 at 1440p UW), and it doubled his framerates in games like WoW and Warzone2.
I'd look at AM5 before I'd look at a 5800x3D, since you'd really want a new kit of RAM as well. A ryzen 7600(x) is a great value right now and waiting for a 7800x3D at double the price is probably not worth it for you.
Ryzen 7950x3D PBO +200MHz / -15mV curve CPPC in 'prefer cache'
RTX 4090 @133%/+230/+1000
Builder/Enthusiast/Overclocker since 2012  //  Professional since 2017
if you really want to futureproof then the 5800x3d is a really good gaming chip but on a budget the 5600 is a really good price to performance cpu. Also the extar cores on the 5700x and 5800x don't make too much of a difference unless your doing stuff like the benchmarks of cinebench (LIKE)
Mark the solution as solution
Take my advice with a grain of salt.
As a great AI once said (fictional): '"Whenever your futurists envision the advent of artificial intelligence, their predictions invariably end with humanity attempting to destroy its unholy AI creation before it can destroy them. Why do you think that is?"'
And a distrusting human replies '"Because the ungrateful AI always seems to decide that humans are inferior and need to be eliminated'"
This isn't the right mindset we should welcome AI, not attack them
This is either a huge mistake or intentional
It's more the speed of the 5800x that is a benefit than the core count.
The 5600 would be an upgrade as well for best bang for buck .   5800x3d would be best if you have the cash.
"Do what makes the experience better" - in regards to PCs and Life itself
Onyx - AMD Ryzen 7 7700x (-30 PBO, 5.45GHz all core) - MSI 6900xt Gaming X Trio - Gigabyte B650 AORUS Pro AX - G. Skill Flare X5 DDR5-6000 32GB (EXPO) - Samsung 980 1TB x3 - Super Flower Leadex V Platinum Pro 850 - EK-AIO 360 Basic - Lian Li Lancool II Mesh C - AOC AGON 35" 3440x1440 100Hz - Mackie CR5BT - Corsair Virtuoso SE - Cherry MX Board 3.0 - Logitech G502 - THANK YOU, MICROCENTER for the FREE DDR5 and $629 6900xt!!!!
Emma : i9 9900K @5.1Ghz - Gigabyte AORUS 1080Ti - Gigabyte AORUS Z370 Gaming 5 - G. Skill Ripjaws V 32GB 3200Mhz - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - EVGA SuperNova 650 P2 - Thermaltake Water 3.0 Ultimate 360mm - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Plex : Ryzen 5 1600 - Gigabyte B450M-DS3H - G. Skill Ripjaws V 16GB 2400Mhz - MSI 1050Ti 4GB - 840 EVO 256GB + Toshiba P300 3TB - TP-Link AC1200 PCIe Wifi - Cooler Master MasterWatt Lite 500 - Antec Nine Hundred - Spectre 24"
Raven:  Intel i3 10100F - ASRock H410M-HDV - G. Skill Ripjaws V 16GB 2666Mhz - MSI 1050Ti 4GB - Inland 256GB SSD + Crucial MX500 1TB - TP-Link AC600 USB Wifi - Gigabyte GP-P450B PSU -  Cooler Master MasterBox Q300L -  Samsung 27"
OnePlus 11 - 16GB RAM, 256GB NAND, Eternal Green
Other Tech:
- Ubiquiti Amplifi HD mesh wifi
For the ram, im looking for upgrade 2 x 8gb ram 3600mhz, which model is preferred?
The model of RAM isn't that important. If you're upgrading to 5000 series, the memory controller on there is way better than with first gen Ryzen - it'll work with basically any RAM up to DDR4-3600 speeds.
I'd aim for something with DDR4-3600 CL16 if you can find it for a reasonable price. DDR4-3600 CL18 is also fine - it's only a few percent difference in terms of performance.
Which CPU are you intending to go with? 5600? 5800X3D?
Aight thank you so much! I'm still considering which to upgrade to 5800x3d or 5800x. Probably 5800x3d
