Help me choose!!!
Go to solution Solved by filpo,
25 minutes ago, swagohioww said:
Okay so i have two laptops that i should buy one is dell g15 5515 rtx 3060 120hz ryzen 7 5800 16gb ram and msi gf65 10ue rtx 3060 I7 10750 with 144hz and idk which one to buy they both seem great. i want a good laptop that can last with me good amount of years good for gaming and coding!
the dell g5 due to its better ryzen processor
https://linustechtips.com/topic/1497471-help-me-choose/
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
https://linustechtips.com/topic/1497471-help-me-choose/#findComment-15868318
The Dell for sure, the G15s, G5s, and G7s also have really great build quality and Dell's customer support is pretty solid. MSI gaming laptops are a bust, I can't recommend them. I see them all the time in my shop for dead motherboards, or broken components, they're build quality is just abysmal on some of their units.
Check on delloutlet.com and see if you can find a certified refurbished of the same or a better laptop, you can score some insane deals. Even the scratch and dent are in new condition, usually just have a minor scratch or dent on the top or bottom of the laptop, I've never gotten a used laptop from them, it's just how they sell their blemished laptops pretty much that had very minor cosmetic damage during assembly, they still have full warranty and everything. But you can find discounts on models from 30% to 50% or more. Dell Outlet is the way to go when looking into getting any Dell laptop.
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z790 Aorus Elite AX | GPU - PNY Gaming OC RTX 5080 16GB RAM - Corsair Vengeance Pro RGB 64GB 6400mhz | AIO - Arctic Liquid Freezer III 360mm | PSU - Corsair RM1000X | Case - Hyte Y40 - White | Storage - Samsung 980 Pro 1TB Nvme /  Sabrent Rocket 4 Plus 4TB Nvme / Samsung 970 EVO Plus 2TB Nvme / Samsung 870 EVO 4TB SSD / Samsung 870 QVO 2TB SSD/ Samsung 860 EVO 500GB SSD|
Phone: Samsung Galaxy S26 Ultra - Black 256GB |
https://linustechtips.com/topic/1497471-help-me-choose/#findComment-15868363
i love you thanks for your advice
https://linustechtips.com/topic/1497471-help-me-choose/#findComment-15868481
