i have an rx5500 gpu (not xt)  and it just recently stopped working completely. To give a little background, i had bought a new mobo and cpu, i remembered i didnt have a fan that would work wth the new mobo so i tried using the exhaust fan and ofc it didnt cool the cpu, so i tried once again with an incompatible cpu fan and it worked for a sec then overheated, so then i moved everything back to my old mobo including my old cpu, and the gpu didnt work, i tried the gpu on the new one and it didnt work either.. im not sure if i had to much esd and killed it or if theres still hope... if theres anyway to remove esd or troubleshoot this PLEASE REPLY!!!
https://linustechtips.com/topic/1496772-graphics-card-help/
Why are you convinced esd had something to do with it?
Corps aren't your friends. "Bottleneck calculators" are BS. Only suckers buy based on brand. It's your PC, do what makes you happy.  If your build meets your needs, you don't need anyone else to "rate" it for you. And talking about being part of a "master race" is cringe. Watch this space for further truths people need to hear.
https://linustechtips.com/topic/1496772-graphics-card-help/#findComment-15863048
26 minutes ago, AthenaRose said:
bc it wont work ...the fans wont spin..nor display on my monitor
OK. There are a lot of possible causes for that. Why do you jump right to esd? The fact that's the conclusion you go to immediately makes it seem like info is being left out here, and that makes it harder for us to help you? Are you shuffling around on a 1970's shag carpet in wool socks the whole time you're working on the PC?
https://linustechtips.com/topic/1496772-graphics-card-help/#findComment-15863110
using modern basement carpet, i don't have room on the table so i did it on the floor
https://linustechtips.com/topic/1496772-graphics-card-help/#findComment-15863162
no socks either
https://linustechtips.com/topic/1496772-graphics-card-help/#findComment-15863185
