Installed new cpu ryzen 7 5700x
Getting bsod now watchdog timeout error resented to default settings still getting bsod
Full spec list
3070ti evga
850 w corsair rm 80 plus gold
Ssd 860 Evo 1 tb
16 gb ddr4 3000 mhz
Ryzen 7 5700x
B450-f Roger strix gaming mobo
I am really annoyed and pissed off I've been trying to fix this issue to Just play some games with my bro overseas please someone help
https://linustechtips.com/topic/1496619-need-help-asap-please/
Are you on the latest bios? Windows 10 or 11? Watchdog Timeout can be quite a few things, from unstable clock speeds and voltages to bad firmware and drivers.
https://linustechtips.com/topic/1496619-need-help-asap-please/#findComment-15861988
im on the latest bios and windows 10 also I just updated my amd drivers to the newest version
https://linustechtips.com/topic/1496619-need-help-asap-please/#findComment-15861991
also i have been messing with ftpm since it was making my games stutter
https://linustechtips.com/topic/1496619-need-help-asap-please/#findComment-15861994
Turn off XMP if its on, see if it boots. Its basically going down the troubleshooting list of what could be the potential problem.
https://linustechtips.com/topic/1496619-need-help-asap-please/#findComment-15861997
I only crash one I boot into a app called bluestacks its a android emulator I have already tried turning off xmp
https://linustechtips.com/topic/1496619-need-help-asap-please/#findComment-15861998
I have no issue booting into windows its only when I launch bluestacks that I get bsod have not tried it with any other games yet but firefox etc runs fine
https://linustechtips.com/topic/1496619-need-help-asap-please/#findComment-15861999
If EVERYTHING else works, but bluestacks is failing, there is something wrong with your blue stacks emulation. Youve tried other games and other programs and they all work but Blue stacks is the only thing that causes it? Uninstall it completely and try it again. Could always do LDPlayer i think that is what its called.
https://linustechtips.com/topic/1496619-need-help-asap-please/#findComment-15862000
okay ill give it a shot thanks
https://linustechtips.com/topic/1496619-need-help-asap-please/#findComment-15862002
