i need help finding a case for my motherboard
Solved by Hinjima,
29 minutes ago, yo i like pugs said:so i got this msi p67a-gd65 but i cant find a case anywere if anyone could tell me a compatible case for my motherboard that whould be very nice thanks in advance
Thats a normal ATX sized board. Any standard PC case will fit this, ATX is the most common motherboard size. If you are unsure if you have found a case that fits ATX, you can look it up on the case's manufacturer website under technical specs and it should be listed
This is just a normal motherboard.
