Not enough bandwidth??
Go to solution Solved by Pikatchu,
@Ebony Falcon@filpo@Electronics Wizardy
Thank you all for your inputs, this seems to be a BIOS issue with Asus boards.
Asus board's BIOS seems to not be in a stable state yet, plenty of complaints.
This is primarily an issue with slow software's opening time.
I am currently using a 7900x with B650E-F motherboard, RTX 3080, and 3 m.2 SSDs.
When I have the graphic card installed, my software have significant delays when opening them, like up to 15 seconds.
When I remove my graphic card, the software will open instantly with no noticeable opening time.
Is this a CPU PCIE limitation? Or motherboard's limitation?
Per the motherboard's spec, it did not say anything about m.2 slot sharing lanes with x16 slot, for the ones connected to CPU directly.
I have 2 gen4 SSDs and 1 gen3. Slot 1 have gen4, slot 2 have gen3, and last slot gen4.
I have tried rotating the drives around the slots; same outcome. No matter how I arrange them, software will launcher very slowly with my graphic card installed.
Full time technology enthusiast, part time IT.
https://linustechtips.com/topic/1494937-not-enough-bandwidth/
check at what bandwidth your pcie slot is currently at in the bios
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
https://linustechtips.com/topic/1494937-not-enough-bandwidth/#findComment-15848498
They are on the appropriate gen speed. Gen4 for all except for the gen3 ssd, which is at gen3.
Not sure how to check bandwidth, what do you mean by bandwidth?
https://linustechtips.com/topic/1494937-not-enough-bandwidth/#findComment-15848507
i mean the slot for the graphics card and to check it you need to go into the BIOS, go under general settings, then pcie subsystem settings then pcie link speed and see what speed your gpu is bound to
Total: £1040.95
https://linustechtips.com/topic/1494937-not-enough-bandwidth/#findComment-15848509
5 minutes ago, Electronics Wizardy said:
What software is this? Does it affect other software?
This seems like a weird issue with the software and not due to system bandwidth.
It is steam.
Though, it is weird that removing the gpu will solved the slow software startup. This got me thinking about bandwidth or PCIE lane allocation issue.
All bandwidth is normal, at the correct speeds.
https://linustechtips.com/topic/1494937-not-enough-bandwidth/#findComment-15848529
It is steam.
Is task manager showing anything weird?
Id guess its waiting on a driver or something, and has nothing to do with disk io.
https://linustechtips.com/topic/1494937-not-enough-bandwidth/#findComment-15848531
Ye i second this. Check your chipset and bios is up to date as well as network adapter drivers
Total: £1040.95
https://linustechtips.com/topic/1494937-not-enough-bandwidth/#findComment-15848537
BIOS version 1222
Shipset V5.01.03.005
All seems fine, there is a steam(32bit) background task running when I click open. After awhile, Steam's bundle of tasks will show up in app.
If steam is already started, it will run a 2nd steam(32bit) task in background task, after awhile then bundles the client service and client webhelper to app.
https://linustechtips.com/topic/1494937-not-enough-bandwidth/#findComment-15848555
https://linustechtips.com/topic/1494937-not-enough-bandwidth/#findComment-15852440
