So about three months ago I tried to enable TPM and Secure Boot for my PC which I built (specs down below) and it wouldn't show me the ASUS Loading screen and instead jumped to windows, I also tried entering BIOS from advanced startup and it just did the same thing, after a few times restarting my computer started not connecting to my Monitor. I troubleshooted by switching monitors, Cables, and ports but no matter what I did the display was not detecting my PC but the computer was still working. So from here I took it into a shop and they plugged it in and it immediately started working when he connected it so I took it back to my place and it worked and my monitor detected the display. After working fine for a couple of months I tried again, this time I was able to enter the BIOS and found that TPM was already on but for some reason secure boot was set to Custom OS and Legacy Mode (This may have occurred cause when I built this PC I cloned my older 2017 Gaming PC's Boot Drive from an SSD onto my new M.2). After that I changed it back to UEFI and Standard Mode then saved the settings and then disaster struck. My PC would not turn on no matter what I did so I took it to a different shop and it wasn't powering on till they ran their diagnostics tool it randomly started working and the diagnostics tool found nothing. I again brought it home but it was still not powering on and only started working after I turned it on with the front panel removed and I remembered that the original problem I had also resolved after turning the computer on with the front panel removed. I thought the issue might be the power supply but the multimeter says its\'s functioning properly and it's working right now so while this might be crazy I think the issue might have something to do with the magnets on the Corsair 4000X front panel but I may be wrong (BTW I dislike this case in general because it has poor ventilation and it's difficult to build in). Anybody have any other theories about this let me know so I can try to troubleshoot before this happens again.
- Parts List
    Intel Core i9-11900K 3.5 GHz 8-Core Processor
    Cooler Master Hyper 212 RGB Black Edition 57.3 CFM CPU Cooler
    Asus PRIME B560M-A Micro ATX LGA1200 Motherboard
    Corsair Vengeance RGB Pro 32 GB (2 x 16 GB) DDR4-3600 CL18 Memory
    Western Digital Green 240 GB 2.5" Solid State Drive
    Toshiba P300 2 TB 3.5" 7200RPM Internal Hard Drive
    Seagate Barracuda Compute 4 TB 3.5" 5400RPM Internal Hard Drive
    Samsung 970 Evo Plus 500 GB M.2-2280 NVME Solid State Drive
    Gigabyte GeForce RTX 3060 12 GB AORUS ELITE Video Card
    Corsair iCUE 4000X RGB ATX Mid Tower Case
    Corsair HX Platinum 1000 W 80+ Platinum Certified Fully Modular ATX Power Supply
    Gigabyte GC-WBAX210 802.11a/b/g/n/ac/ax PCIe x1 Wi-Fi Adapter
https://linustechtips.com/topic/1494124-weird-unexplainable-pc-issues/
I had an issue not being able to get into my bios before too, cant remember what CAUSED it, but I remember jumping the cmos pin with a flathead AKA resetting cmos, worked for me.
Jesus is the way, the truth, and the life.
Please Quote me when replying.
CPU
 - Ryzen 7 5800X3D | RAM - 32GB DDR4 4000Mhz | MB - MSI B550 A-PRO | Boot - 2TB NVME 980 Evo Plus | GPU - EVGA FTW3 RTX 3090 24GB
Mine started up and allows me to enter BIOS now without ever having to jump the CMOS
Awesome 😎
CPU
Using the latest Bios?
Latest GPU firmware?
https://www.gigabyte.com/Graphics-Card/GV-N3060AORUS-E-12GD-rev-10/support#support-dl-firmware
Does the same happen with XMP off?
Because that platform hardly supports 3600.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
Yes, also all my drivers and Bios are up to date
