CPU Cooler installation
Solved by Poinkachu,
5 minutes ago, Sima01 said:AM4 boards have backplate installed by default, I just need to put on the cooler and screw the hand bits to hold it on. So I guess it should be an easy proccess.
This is the guide on it https://www.youtube.com/watch?v=AK7qj3_b_UM
DAMN, your signature is true, ill just put the case over two tables revealing the back easily.
Oo yea, you can do it without taking off motherboard off the tray.
Hahah, overengineered solution
