What is the manufacturer or brand of the fans?
If the fans came with the computer case you may have to connect it to the case hub if there is one provided.
If you bought the fans separately then you have to buy into the same brand for proprietary hub or components.
CPU: AMD Ryzen 9 3950X聽 聽Motherboard: MSI X570 Gaming Edge Wifi聽 聽Case: Deepcool Maxtrexx 70聽 聽GPU: RTX 3090聽 聽RAM: Corsair Vengeance LPX 3x16GB 3200 MHz 聽 PSU: Super Flower 850W
https://linustechtips.com/topic/1493529-please-help-me/#findComment-15838932
