If I am in the wrong place, please kindly let me know. I am new here and not sure I am where I need to be.
When I started up my MSI command center it says, "not recommended CPU voltage".
I have never messed with the settings. They are set at the default: -1.5600 for CPU Voltage and 1.2125 for CPU NB Voltage.
I do not overclock.
https://linustechtips.com/topic/1493431-not-recommended-cpu-voltage/
<-- Moved to CPUs, Motherboards, and Memory --> 🙂 Welcome to the Forums!
Community Standards
"Beast Mode"
Dedicated Streaming Rig
what are your system specifications? different CPUs have different normal voltages.
so far though, it seems a bit high for a normal default BIOS. have you tried just resetting everyhting?
