Will it fit?
Go to solution Solved by SorryBella,
Dont beat yourself over it too much. Spec sheets tells you most of the story.
Quote
Liquid Cooler Support: Top:120/140/240mm
To be fair, certain 240mm only case could fit a 280mm, but jankily. TBH id go for 240mm AIO instead as it isnt as big of a leap as going from 240mm to a 360mm for example. Or aircooling it.
Howdy!
So im getting a new AIO soon and I was wondering if the NZXT Kraken X63 RGB 280mm AIO Liquid Cooler will fit in my Matrexx 50.
I know it fits in the front panel but im wondering if it would also fit on top. I've been searching for a whole week and im either blind, can't math or im actually the first person on the internet to ask that question (Im probably being dumb)
I'll leave a link to the case & aio below, hopefully someone can answer me cause my brain is going numb.
Deepcool Matrexx 50
Sooo...tldr:
Can I fit this AIO on top of this case or will it only fit in the front panel.
Thanks a bunch!
https://linustechtips.com/topic/1493370-will-it-fit/
Quote
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
https://linustechtips.com/topic/1493370-will-it-fit/#findComment-15837724
