Need help on vmware, vm resolution is scuffed
Solved by SticksDev,
You most likely need to install the VM tools for that version of linux. It's also noted that elematryOS requires the VM to be in UEFI mode. For the resolution to be correct.
You can change that in the advanced settings of the VM.
6
popularlion ·
Posted in Troubleshooting4 -
2
CallMe_David ·
FancyPants101 ·
Posted in Troubleshooting1 -
BoBo6107 ·
R_public ·
Posted in Networking15 -
apoyusiken ·
Posted in PC Gaming9
