Help picking a psu- first build
Go to solution Solved by Hinjima,
29 minutes ago, IDLESHARK said:
Budget (including currency): roughly $1,500
Country: United States
Games, programs or workloads that it will be used for: Gaming/School
BUILD
CPU: 12600K
Cooler: Corsair iCUE H100i Elite Capellix 240mm
Motherboard: Asus Prime b660 ATX
Ram: Corsair Vengeance 32g 3200
Storage: Western Digital SN770 1 TB
GPU: Asus Dual OC V2 RTX 3070
Case: Corsair 4000x
PSU: TBD
I am currently a full-time engineering student therefore I am looking for reliability plus gaming. I opted for the 12600k over the 12600KF due to the integrated graphics. If the GPU fails or I need to troubleshoot I can use the IG to continue school work or whatever else I may need.
I've read online in order to determine the amount of wattage required is as simple as adding peak CPU and GPU wattage. Then add 150W for MOBO, plus an additional 150W for headroom.
I assume I'll need a 750W power supply but I don't if getting 850w is overkill. I understand that these PSU's also have an efficiency curve but I'm not very familiar with them.
P.s. I know I should probably get a Z690 motherboard but overclocking is not really in my interest at this time.
If I could get some advice on choosing a good power supply that would be fantastic along with any further advice on the build. Again, this is my first build.
750w will do for that build but the price increase for an 850w is not a lot and it gives you a decent boost in wattage for upgrades later.  I love my RM750i / RM850x.
BUILD
CPU: 12600K
Case: Corsair 4000x
PSU: TBD
https://linustechtips.com/topic/1492487-help-picking-a-psu-first-build/
BUILD
CPU: 12600K
Case: Corsair 4000x
PSU: TBD
Here is a list with a very(might be overkill) good PSU within your budget with your current parts.
https://pcpartpicker.com/list/pFDQ4s
and here is a list with a better GPU for the same price.
https://pcpartpicker.com/list/2vMMhk
Please mark as solved if I answered your question.
The 12600K and 650W is way to weak for a 4070TI, the CPU will be bottlenecked
The 4070TI requires 700W alone.
Don't know much about engineering, but from what I've heard, a better GPU is more important that a better CPU in most engineering applications. As for the power requirements, just set power limits and undervolts. The only way to stay on budget. Or you could get a 750w, although youll get to about $100 overbudget. Also the 4070ti doesn't draw 700w. Not even close. It peaks at around 320w.
