I recently got an owc dualbay usbc 3.1 gen 2 dock . it works great and the dual bays can use drives completely separate which different drive letters also. Problem is now in file explorer some of my drives are listed twice but only in the left side. Is there a way to fix this ?
Thanks
Edit: After several reboots it resolved itself idk .
Edited by MindFog
fixed
https://linustechtips.com/topic/1491919-duplicate-drive-issue-help-removing/
