hello!
im having this weird issue where PC will shut off with no warning after gaming a little bit on max setting (Only with games that can push GPU, doesn't happen to lower end games and it doesn't randomly shutdown for anything else except gaming at max setting). Temp looks good, System detected unknown shutdown but didn't provide a specific error. my only guess is it is possible that aging PSU be the problem because it is 8 year old... One more thing to mention, this issue started after swapping from 2060 Super to A770 16gig... like i said i think PSU may be getting old that is unable to handle the just a little more load... what your thoughts?
  • Window 11 Pro 64 bit Version 22H2 OS build 22621.1265
  • AMD Ryzen 9 3900X at 4.28 GHz
  • 16.0GB Dual-Channel EVGA brand @ 1799MHz (16-19-19-39) XMP profile 2
  • MPG X570 GAMING PLUS (MS-7C37)
  • Intel Arc A770 Limited Edition Dual Fan 16gb recently swapped from 2060 Super
  • EVGA SuperNOVA 750 G1 120-G1-0750-XR 80+ GOLD 750W from 2015
  • 953GB SanDisk SDSSDH3 1T02
  • 953GB PCIe SSD
Certainly possible. I'd test it to be sure.
I don't badmouth others' input, I'd appreciate others not badmouthing mine. *** More below ***
MODERATE TO SEVERE AUTISTIC, COMPLICATED WITH COVID FOG
Due to the above, I've likely revised posts <30 min old, and do not think as you do.
THINK BEFORE YOU REPLY!
Did you use a program like DDU to uninstall the Nvidia drivers before you installed the Intel card?
It could be a driver confliction if you never removed the Nvidia drivers. That PSU should be able to power the card no problem but if it is that old, it's more than a possibility. I'd say testing a different PSU won't hurt.
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z790 Aorus Elite AX | GPU - PNY Gaming OC RTX 5080 16GB RAM - Corsair Vengeance Pro RGB 64GB 6400mhz | AIO - Arctic Liquid Freezer III 360mm | PSU - Corsair RM1000X | Case - Hyte Y40 - White | Storage - Samsung 980 Pro 1TB Nvme /  Sabrent Rocket 4 Plus 4TB Nvme / Samsung 970 EVO Plus 2TB Nvme / Samsung 870 EVO 4TB SSD / Samsung 870 QVO 2TB SSD/ Samsung 860 EVO 500GB SSD|
Phone: Samsung Galaxy S26 Ultra - Black 256GB |
I did DDU before swapping over. it works without any issues except in case where i game on max setting for a period of time.. like a hour. so i was thinking PSU could be an issues. but i can say EVGA had some rock-solid PSU in my opinion. lasted 8 year and could power almost everything even at OC state... i just think the PSU is getting to the point where it not stable with pulling 600-700 watt...
