Hi All,
I have the following hardware:
Gigabyte X670 AORUS ELITE AX AM5 ATX Motherboard
AMD Ryzen 9 7900X 12-Core AM5 4.70 GHz Unlocked CPU Processor
G.Skill Trident Z5 32GB (2x 16GB) DDR5 6000MHz CL36 Memory
I have had issues since I got it where the pc boots fine, shuts down fine, and starts from a shut down fine. But takes a LONG time to reboot, and often when it reboots it comes up with overclocking failed. Then you go into bios, don't change any settings and it comes back. Lately this has gotten even worse to the point that it actually crashes and I have to power cycle the pc several times to even get it to post. When it doesn't post the dram light is on the motherboard, which is usually on until it posts. Once it boots into windows, i have no issues. Until tonight where the pc fully crashed for the first time, no blue screen and wouldn't post.
Troubleshooting:
Tried all major versions of Bios as well as the newest version, none appear to affect the issue at all.
Tried upping the voltage of the memory to see if it was a stability issue, no dice.
Tried undeclocking the ram to 5600 or 5200, and no change to the issue.
Tried all variations of settings that I have found online, no change.
Tried starting with one ram stick at a time, moving their slots (currently in the A2-B2 slots as suggested by manufacturer).
The only thing that works is turning off xmp completely (meaning running at a sluggish 4800mhz). However when rebooting the same initial issue arises where I have to hard power off my pc then on again after a reboot to get it back up and working.
Anyone got any ideas or additional steps of troubleshooting that I could try?
https://linustechtips.com/topic/1491096-pc-wont-boot-using-xmp/
Is there an EXPO version of the RAM? That should work better with AM5, as G.Skill is on the QVL list.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose, Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1491096-pc-wont-boot-using-xmp/#findComment-15821449
I have tried Enabling EXPO, same issue. Also, updated the main post: My pc is still having the issue where I reboot to a black screen. Have to power off manually, then power on and it comes back. Even with XMP disabled 😞 logging a case with gigabyte now also. But can't figure this out.
https://linustechtips.com/topic/1491096-pc-wont-boot-using-xmp/#findComment-15821462
So ram isn't working even on auto settings (default) on 4800mhz, witch everything set to auto? If that's the case, you got a bad memory stick most likely.
Gaming PC:
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: Crucial 2x16gb, 3200  JEDEC. | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Asus Prime RTX 5070ti OC| Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: Kingston Renegade 2TB and Corsair MP510 960gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
Linux PC:
CPU: Ryzen 7700| Motherboard: Asus A620M-CSM | RAM: Crucial Pro 2x48gb, 5600  JEDEC. | PSU: Corsair CX750 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: MSI Gaming X RTX 3090 | Case: Lian Li Dan Cases A3-mATX black |Storage: SN7100 2TB + Samsung 860 EVO 512gb | Cooling: CPU: Thermalright Peerless Assassin Mini Fan(s): Noctua 1x NF-A14x25 Chromax
https://linustechtips.com/topic/1491096-pc-wont-boot-using-xmp/#findComment-15821467
But when I'm in windows, and it is booted. I can play games etc no problem. Wouldn't it be crashing more often if it was bad memory? I was leaning towards a motherboard issue :S
https://linustechtips.com/topic/1491096-pc-wont-boot-using-xmp/#findComment-15821470
Not necessarily. I would try another kit first. Ram kit is most likely to be the cause. I can't rule out that a bent pin in the CPU socket could do the same thing.
Gaming PC:
Linux PC:
https://linustechtips.com/topic/1491096-pc-wont-boot-using-xmp/#findComment-15821479
Wouldn't the CPU error light be on the motherboard then rather than the dram light?
Unfortunately I have no other PCs with DDR5 ram to test 😞 Would have to buy some ram to check if it boots and functions normally first 😞
https://linustechtips.com/topic/1491096-pc-wont-boot-using-xmp/#findComment-15821484
Depends, if it affects the area which controls the memory controller it could be lighting up in memory and then you could also say it's memory related.
I actually tried something similar along time ago. I managed to fry a memory controller on a i7-875K, from overclocking, resulting in all the pins burning to the cpu socket. CPU was still able to run ram at stock speeds 1333/1600mhz, but anything over wouldn't work.
Gaming PC:
Linux PC:
https://linustechtips.com/topic/1491096-pc-wont-boot-using-xmp/#findComment-15821486
Well the issue now is that even without the settings I am experiencing the shutdown issue. So manually setting the frequency and timing may not change anything. But I'll give it a try.
Also Ran Memtest overnight with no errors. Not sure memory is the issue here, could it be motherboard? Was thinking of buying a different brand of memory and seeing how that goes, but now i'm not sure if would make a difference...
https://linustechtips.com/topic/1491096-pc-wont-boot-using-xmp/#findComment-15822135
Tried manually overclocking to the voltage/latency/frequency specified. But same thing happened. Booted fine, totally stable. Then upon restart it wouldn't post. Had to power off many times, and then have 1 stick in at a time to get it to post where i could reset to defaults and disable XMP in bios. Rolled back bios to earlier, same issue.
At this point pretty much have to buy new RAM just to test if it is RAM. If issue happens with another brand of RAM that says it is made for AMD. Then It has the be motherboard/memory controller. Then it gets messy 😞
Just sucks that it was working fine, just with a really really long reboot until I updated the bios (trying to fix the long reboot issue). But going back to the same version I had, this issue is still there.
https://linustechtips.com/topic/1491096-pc-wont-boot-using-xmp/#findComment-15822258
  • 4 weeks later...
So update to this one: Basically when I bought my memory, I looked up best Memory for AM5 across several different sites, all of them leaned towards the RAM that I purchased. The site I bought from, the gskill webpage etc all said AMD/INTEL compatible.
However now when I look up my RAM it says Made for INTEL only. Same with the site where I bought the RAM originally. Now there is an EXPO AMD version of the same RAM that is separate. Wonder if there was some kind of microcode update for the cpu that caused this RAM to no longer be compatible (after working for 5-6 months with no issues other than slow reboots).
I ordered 5600MHz definitely made for AMD EXPO Corsair Vengence RAM and haven't had an issue since. So this was definitely the RAM, and not faulty RAM just incompatible RAM, after working fine for 5-6 months...
https://linustechtips.com/topic/1491096-pc-wont-boot-using-xmp/#findComment-15865389
