Clean format of drive
eco_bach
Doing a complete reformat of my drive before I upgrade to Windows 11.
Does it matter which method or utility I use or are they all the same?
4 minutes ago, Oshino Shinobu said:
If you're installing Windows again anyway, just format it using the Windows installer.
Yeah this is the easiest way to do it I think. If I remember, just delete all the partitions and then format. Takes like a minute.
