I have a 4 year old LSI HBA 9300-8i behaving weird one day. It wont boot to its bios and showed the "fault 05h" message. I posted recently about this and a flash to a new firmware was advised. I havent flashed an HBA card before so I was looking around the forum and the internet and no luck for me and was not able to find the specific methods to get it to work from making a USB boot drive to make the sas3flash to boot into DOS. I then tried to boot it in another machine, still no luck there. A few hours ago I tried to install the card back to the machine and then miraculously it booted. I check the firmware and it is on ver 16.0.0~. So I figured it does not need a flashing to a new version. I turned off the machine so that I can slap back all the drives and then on reboot it failed again and wont boot giving me the fault 05h. I suppose this could be an overheating problem and opened the card and here are my findings. Any thoughts?
https://linustechtips.com/topic/1490510-9300-8i-hba-problem/
Sounds like corrupted firmware, re-flash it even though it might the the current latest version. Also as a test disconnect all the disks and see if it boot properly. If it failed every time the disks are connected then you could have a faulty disk that is caused this problem.
https://linustechtips.com/topic/1490510-9300-8i-hba-problem/#findComment-15817277
Thank you for the reply. I checked all the drives and no faulty disks. Loaded all the disks to a different adapter. I also noticed while replacing the thermal paste of the HBA card, I see a chip on the periphery of the card. You may refer to the pictures I attached. I dont know if it is really major. Been using the card for almost 4 years.
https://linustechtips.com/topic/1490510-9300-8i-hba-problem/#findComment-15817283
Sounds like either a firmware corruption as @leadeater mentioned, or some sort of hardware fault.
Follow his suggestion first about re-flashing the firmware, though since it booted again once fine I think it could be the latter.
The LSI BGA chip you posted is the ROC (Raid on Chip) which is the ROM and what does all the computation.I think its highly unlikely from a hardware perspective thats where the issue is since you got it to boot again.  There are a number of SOIC's on the board though, and I would hazard a guess that perhaps one of them has a dry leg and something isnt switching properly.
The below SOP-8 chip with the 8 legs is what im talking about. You probably have a few of these. You could use a small pair of tweezers and some sort of magnification to just nudge each leg and make sure theyre properly seated and not cracked joints. It could be that one of these just needs solder to be reflowed.
Desktop: Ryzen9 5950X | ASUS ROG Crosshair VIII Hero (Wifi) | EVGA RTX 3080Ti FTW3 | 32GB (2x16GB) Corsair Dominator Platinum RGB Pro 3600Mhz | EKWB EK-AIO 360D-RGB | EKWB EK-Vardar RGB Fans | 1TB Samsung 980 Pro, 4TB Samsung 980 Pro | Corsair 5000D Airflow | Corsair HX850 Platinum PSU | Asus ROG 42" OLED PG42UQ + LG 32" 32GK850G Monitor | Roccat Vulcan TKL Pro Keyboard | Logitech G Pro X Superlight  | MicroLab Solo 7C Speakers | Audio-Technica ATH-M50xBT2 LE Headphones | TC-Helicon GoXLR | Audio-Technica AT2035 | LTT Desk Mat | XBOX-X Controller | Windows 11 Pro
Server: Fractal Design Define R6 | Ryzen 3950x | ASRock X570 Taichi | Asus RTX 4060 Dual OC | 64GB (4x16GB) Corsair Vengeance LPX 3000Mhz | Corsair RM850v2 PSU | Fractal S36 Triple AIO + 4 Additional Venturi 120mm Fans | 8 x 20TB Seagate Exos X22 | 4 x 16TB Seagate Exos X18 | 3 x 2TB Samsung 970 Evo Plus NVMe | LSI 9211-8i HBA
NAS: Innovision 4U 24-bay chassis (12GB MiniHD SGIO Backplane) | Intel Core i9-10980xe | EVGA X299 FTW-K | EVGA RTX 2080Ti Super FTW3 | 128GB (8x16GB) Corsair Vengeance LPX 3200Mhz | DEEPCOOL PN1000M PSU| Noctua NH-D12L Chromax Black | 16 x 16TB Seagate Exos X18 | 2 x 2TB Samsung 990 Pro | 2 x 2TB Intel U.2 P4510 | LSI 9305-24i HBA
https://linustechtips.com/topic/1490510-9300-8i-hba-problem/#findComment-15819325
