Hi, Im really on a tight budget and parts in the country I live in (Philippines) is a bit more expensive.
Used for gaming. (World of Tanks, Crysis, Bioshock Infinite, Wargame Red Dragon, League of Legends, Dota 2, Skyrim)
Processor: FX-6300
Mobo: GA 970a DS3
GPU: Sapphire R9 270 Dual-x
Case: Cooler Master N300
Ram: Crucial 2x4gb 1600mhz
HDD: WD Blue 1tb
CPU: Cooler: Noctua NH-C12P SE14
PSU: Still thinking aobut it, could use some suggestion.
Could use some suggestion in some parts, again, in a tight budget, wont afford upgrading more. :))
First post btw.
https://linustechtips.com/topic/149026-my-first-build/
If your grave doesn't say "rest in peace" on it You are automatically drafted into the skeleton war.
https://linustechtips.com/topic/149026-my-first-build/#findComment-1990983
The year is 20XX. Everyone plays Fox at TAS levels of perfection. Because of this, the winner of a match depends solely on port priority. The RPS metagame has evolved to ridiculous levels due to it being the only remaining factor to decide matches.
Only Abate, Axe, and Wobbles can save us.
https://linustechtips.com/topic/149026-my-first-build/#findComment-1990990
I am getting really confused about this i3 and FX 6300 thing, many people are saying FX 6300 is better for gaming, and now it's not. :| jasfjajasod such confuse
Yea it can get confusing. I'd go with the i3 because it would perform better and you can upgrade to an i5 4670K if you wanted.
https://linustechtips.com/topic/149026-my-first-build/#findComment-1991015
For the price difference between an i3-4340 and a fx-6300, it isn't worth it. They are almost identical in tasks when paired with discrete graphics, (which you will have in this system). Check here for some numbers. You are ballin' on a budget here, so price/performance is a big deal. Just stick with the 6300.
//ccap
https://linustechtips.com/topic/149026-my-first-build/#findComment-1991032
I just looked up i3 4340, we don't really have that model here, we only have the i3 4130 which is a dual core cpu, almost same price as the FX-6300.
Oh yeah and thanks for the help guys, really helpful.
Also would take suggestions if u guys know a better case. (same price range please :D)
https://linustechtips.com/topic/149026-my-first-build/#findComment-1991088
