I have just finished doing a custom loop GPU (3070TI) and CPU(I7-12700K) both are currently over clocked just a tad and I’m currently playing hogwarts legacy at max everything just wanted to know if these temps are good I’m in Hawaii so it’s pretty hot in the house at most times and I don’t have AC right now as well if I’d guess the rooms probably anywhere from 68-75 degrees while I’m playing but that’s a rough estimate I also have the fans only at about 7-800 RPMs at the moment but anyways just needed the advice thank you in advance
https://linustechtips.com/topic/1489802-custom-loop-advice/
Assuming 30 degrees ambient, thats impressive for light OC op on gaming load. You can definitely stretch it further if the silicon and PSU can handle it.
Also, id definitely pick something more realtime like HWiNFO64.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
https://linustechtips.com/topic/1489802-custom-loop-advice/#findComment-15812114
9 hours ago, chaotic kronos said:
If what is shown is max temperatures then yeah everything is perfect
It shifts a little bit on intense screen it’s usually anywhere from 48-58 degrees the fans are also set to the quite function on icue
https://linustechtips.com/topic/1489802-custom-loop-advice/#findComment-15812642
It’s a 850W gold rated  so nothing to special I don’t wanna OC to much as I don’t wanna upgrade for a while (besides a 4080/7900XTX in the future) i don’t play a lot of games Valorant,Apex, hogwarts legacy, and overwatch 2 and most of those aren’t to heavy hitter
https://linustechtips.com/topic/1489802-custom-loop-advice/#findComment-15812691
