Fan questions
Go to solution Solved by Alinz,
IMG-20230217-WA0005 is the fan connector. The other one is the ARGB connector.
Just follow the cable, if they both go to the fan then they are both connected to the fan.
I got the phanteks eclipse d RGB p500a
Is this the fan connector?
https://postimg.cc/gallery/67yWcWp/67ecf672
Is this the female argb fan connecter?
https://postimg.cc/gallery/fLtpZtp/1f89d801
Just to be sure are both these wires connected to this fan?
https://postimg.cc/vc3C7HRY
https://linustechtips.com/topic/1488786-fan-questions/
My Rig: CPU : 10700K | RAM : Trident Z Neo 3600Mhz c16 32G (4x8) | CPU cooler : NHD15 | GPU : ASUS ProArt 4070 | PSU : Corsair RM850 (black label) | CASE : Corsair 5000D Airflow | Storage : Samsung 970 evo 1TB, WD Black 1TB, Samsung evo 850 Sata SSD | Casefans : Lian Li Unifan SL120 7X|
MOUSE : G Pro Wireless X superlight | Keyboard : Keychron C1- Pro-H1 Gateron Milky Reds
https://linustechtips.com/topic/1488786-fan-questions/#findComment-15804718
Thanks also I'm new to the forums how do I see upvotes like on Reddit
https://linustechtips.com/topic/1488786-fan-questions/#findComment-15806304
You basicly already did that. The post tagged as the sulution will be displayed at the top of the thread. You can also like, agree ect. Welcome to the LTT forum, enjoy your stay!
https://linustechtips.com/topic/1488786-fan-questions/#findComment-15808431
