Hello!
My friend has the same gpu, and he got older cpu 5900X, he always gets higher fps and perfomance than me...
I don't understand what could cause this problem??
I have i7 13700K, with Corsair Dominator 5600mhz ram and SSD with 7.3GB/s speed, shouldn't I get more fps??
I have tried 1080p,1440p,2160p resolutions, he always beats me with same settings and same drivers...
I can't figure it out, what's wrong
Can anyone help?
https://linustechtips.com/topic/1488408-red-devil-7900-xt-perfomance/
16 minutes ago, himlastar said:
Hello!
Can anyone help?
By how much fps increase are we talking about?  Is your card staying as cool and clocking just as high as his card?
In Cyberpunk 2077 its 10-20fps, in Call of Duty MW 2 its 30 fps,
yea same clock speed, and gpu temp is 50-64 and junc temp is 60-80
42 minutes ago, Jhoeljgc123 said:
maybe there are some unique benefits by having AMD Cpu and Gpu, also have you checked if you have the Smart Access Memory turned on?
I don't have Smart Access Memory, but I have ReBar, I think its the same? That's on.
Yes, it's the same. SAM is simply AMD's marketing name for reBar.
Make sure you're comapring with exactly the same settings on both machines for everything, also check settings in AMDs GPU tool outside the game.
