Tech QUESTION
Solved by YoungBlade,
Just now, Bengvin said:i cant find a gtx 1070 but i can get a second hand gtx 1660 super for 150 dollar. Is it better than gtx 1070?
The 1660 Super is about on par with the 1070 in terms of performance, although it has 6GB of VRAM instead of the 8GB of VRAM on the 1070. It's a decent bit faster than the 1660 and certainly a better buy than the regular 1660 at the same price point.
$150 for a 1660S is still not a great price, but if it's all you can find and it's all you can afford, then it's not the worst deal ever or anything.
