Help needed for RGB connection
Go to solution Solved by matt0725,
if the cooler is addressable (in that the leds can be different colors) you use the ARGB plug, which is D_LED.
The led_C is for 'normal' LED's where every LED will be the same colors.
your AIO is listed as addressable, so you should use the ARGB plug
Hello,
Ive just made my computer but, my AIO says i need to connect the RGB connector to a add_header connection.
The problem being that my MOBO doesn't have that, only a d_led and a led_c connection.
Could i technically connect it to that or would it not work?
Thanks in advance 🙂
(if specs are needed, i got a raijintek eos 360 rbw aio and a gigabyte b550 gaming x v2)
https://linustechtips.com/topic/1487995-help-needed-for-rgb-connection/
