rtx 3060 Theseus PC: CPU fitting for 3060
2 hours ago, SorryClaire said:5th gen is all mobile, are you sure it is an i5 and not a Ryzen 5?
There were 2 desktop chips, one i5 and one i7.
2 hours ago, Enkelados said:Whoops, then I got the number wrong it is an i5 100%. If all 5000 are mobile It has to be a 4000 or 6000. I'll check in the morning.
Most likely an i5 6500, those are very common, and flipping the numbers around is so common that googling "i5 5600" gives results for the i5 6500. Though using one with DDR3 is uncommon, so unless you got one of the few DDR3 boards for skylake then it's gotta be a 4000 series.
2 hours ago, Enkelados said:I would need new ram, MB and CPU in a package, what would be the most appropriate bundle?
One of the modern quad core i3s, a B series DDR4 mobo, and RAM should scrape in around that budget:
PCPartPicker Part List: https://de.pcpartpicker.com/list/Dxwscb
CPU: Intel Core i3-12100F 3.3 GHz Quad-Core Processor (€104.43 @ Amazon Deutschland)
Motherboard: MSI PRO B660M-A DDR4 Micro ATX LGA1700 Motherboard (€135.90 @ Alza)
Memory: G.Skill Aegis 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory (€74.90 @ Alza)
Total: €315.23
Generated by PCPartPicker 2023-02-11 05:32 CET+0100
Can drop to 16GB RAM to save a little bit, but I don't see the point as it's so cheap for a 32GB kit currently, and if you'll use anything that takes advantage of QuickSync then paying up for the non-F CPU is a good idea. That motherboard is the easy pick B660 I know of, someone may know a better model for the budget. That MSI one is just a reasonable price and has the VRMs to handle up to a 12900K if you enable power limits (by default they are disabled), with a BIOS update it'll do the same for 13th gen chips so you can upgrade in the future without needing a new motherboard.
