Budget (including currency): Ideally £800-£1k
Country: England
Games, programs or workloads that it will be used for: Business use (accounting some spreadsheets) occasional gaming (DCS, ACC)
https://uk.pcpartpicker.com/list/3zzmTn
peripherals not included in budget yet.
Not sure if the parts I have are overkill for my use but I do want a good gaming experience. Also like to have good audio quality.
Thanks in advance!
https://linustechtips.com/topic/1487124-help/
@matt_ball4
3050 is a dud as far as GPUs. Does it work? Yes, but it's not a whole lot better than the 1650 / 1660. I would go for a 3060ti if you can swing it. If not, a used 2060 / 2070 / 2080 would be about as good as a 3060 / ti, but be sure you have enough PSU wattage for it.
Also, I have no intention of upgrading to Win11 for many reasons. There is spyware, bloatware and they're trying to tell you how you can and can't use your PC. I would stick with Win10.
Edited by An0maly_76
Revised, more info
I don't badmouth others' input, I'd appreciate others not badmouthing mine. *** More below ***
MODERATE TO SEVERE AUTISTIC, COMPLICATED WITH COVID FOG
Due to the above, I've likely revised posts <30 min old, and do not think as you do.
THINK BEFORE YOU REPLY!
https://linustechtips.com/topic/1487124-help/#findComment-15792568
Afiak sound cards aren't needed anymore since the integrated audio on the mobo is good enough, so something like this would work just fine
PCPartPicker Part List
CPU: AMD Ryzen 7 5700X 3.4 GHz 8-Core Processor (£180.46 @ Amazon UK)
CPU Cooler: ARCTIC Freezer 34 eSports DUO CPU Cooler (£48.44 @ Amazon UK)
Motherboard: Gigabyte B550 AORUS ELITE AX V2 ATX AM4 Motherboard (£139.59 @ CCL Computers)
Memory: G.Skill Ripjaws V 32 GB (2 x 16 GB) DDR4-3600 CL18 Memory (£85.15 @ Amazon UK)
Storage: Samsung 970 Evo Plus 1 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive (£56.58 @ Box Limited)
Video Card: ASRock Challenger D OC Radeon RX 6650 XT 8 GB Video Card (£305.99 @ Newegg UK)
Case: Fractal Design Pop Air ATX Mid Tower Case (£88.99 @ MoreCoCo)
Power Supply: Corsair RM650 (2019) 650 W 80+ Gold Certified Fully Modular ATX Power Supply (£89.99 @ Scan.co.uk)
Total: £995.19
Generated by PCPartPicker 2023-02-09 14:45 GMT+0000
https://linustechtips.com/topic/1487124-help/#findComment-15792569
3050 is absolute aids, i have 2 words for you
Do not.
Dont forget to mark as solution if your question is answered
Note: My advice is amateur help/beginner troubleshooting, someone else can probably troubleshoot way better than me.
- I do have some experience, and I can use google pretty well. - Feel free to quote me I may respond soon.
Join team Red, my apprentice
STOP SIDING WITH NVIDIA
Setup:
Ryzen 7 5800X3DSapphire Nitro+ 7900XTX 24GB / ROG STRIX B550-F Gaming / Cooler Master ML360 Illusion CPU Cooler / EVGA SuperNova 850 G2 / Lian Li Dynamic Evo White Case / 2x16 GB Kingston FURY RAM / 2x 1TB Lexar 710 / iiYama 1440p 165HZ Montitor, iiYama 1080p 75Hz Monitor / Shure MV7 w/ Focusrite Scarlett Solo / GK61 Keyboard / Cooler Master MM712 (daily driver) Logitech G502-X (MMO mouse) / Soundcore Life Q20 w/ Arctis 3 w/ WF-1000XM3
CPU OC: -30 all cores @AutoGhz
GPU OC: 3Ghz Core 2750Mhz Memory w/ 25%W increase (460W)
https://linustechtips.com/topic/1487124-help/#findComment-15792588
Country: England
Thanks in advance!
Latest gen CPU is less expensive for better performance.
Stock cooler is fine for intended use.
Locked CPU are better prepared with B and H chipset motherboards. Z chipset motherboards are intended for unlocked CPU.
Current generations offer WiFi on motherboards at low or no additional cost.
Motherboard audio subsystems generally offer good quality audio.
CPU: Intel Core i5-13400F 2.5 GHz 10-Core Processor  (£199.11 @ Technextday)
Motherboard: MSI PRO B760M-P DDR4 Micro ATX LGA1700 Motherboard  (£117.31 @ CCL Computers)
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  (£44.50 @ Amazon UK)
Storage: Western Digital Blue SN570 1 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  (£55.98 @ Ebuyer)
Video Card: PowerColor Fighter Radeon RX 6650 XT 8 GB Video Card  (£303.48 @ Ebuyer)
Case: Fractal Design Pop Mini Air MicroATX Mid Tower Case  (£103.98 @ Overclockers.co.uk)
Power Supply: Corsair TX650M 650 W 80+ Gold Certified Semi-modular ATX Power Supply  (£62.99 @ Ebuyer)
Operating System: Microsoft Windows 11 Home OEM - DVD 64-bit  (£108.88 @ Technextday)
Total: £996.23
Generated by PCPartPicker 2023-02-09 15:06 GMT+0000
https://linustechtips.com/topic/1487124-help/#findComment-15792616
The mobo and cpu are a total mismatch. The CPU is weak and the mobo is strong, plus it's for overclocking/tweaking. Unless you need what that Z has, you should get a great B mobo instead. If you want to have extra ports and slots, then get an H mobo, which also may have tweaking/OC.
This mobo and many others include wifi and sound, so you don't need those cards.
If you are planning on playing a lot of different games, add another m.2 1TB SSD and install them to it.
I would suggest getting better fans, at least with PWM (4 pins). The Corsair ML120s are very good but about$20/fan in a pack. If you want to throw money at RGB, There are other options, including Corsair.
I've been using computers since around 1978, started learning programming in 1980 on Apple IIs, started learning about hardware in 1990, ran a BBS from 1990-95, built my first Windows PC around 2000, taught myself malware removal starting in 2005 (also learned on Bleeping Computer), learned web dev starting in 2017, and I think I can fill a thimble with all that knowledge. 😉 I'm not an expert, which is why I keep investigating the answers that others give to try and improve my knowledge, so feel free to double-check the advice I give.
My phone's auto-correct is named Otto Rong.🤪😂
https://linustechtips.com/topic/1487124-help/#findComment-15792722
