asus strix rtx 4090 oc temp problem
 Share
hello everyone my spec
asus z690 hero
cpu 13900k
2x16gb g skil 6400
when i install a month ago the gpu temp was ok on stock setings stock fan p bios 3dmark not pass 60c my room temps is the same 20c now my gpu temps in 3dmark time spy goes up to 64-65c my memory temp is 62c hot spot 85-88c i think is very high when i play cyberpunk on stock setings on 4K MAX seting the gpu temp is almost 68c and hot spot 90c does i have problem with my cooler? mybe is the vbios updae? mybe thermal paste?
when i overclock the card to 3ghz with 100% fan i run time spy extreme and my max temp is 75C and 95C HOT SPOT
thanks for the help
thats pretty normal
Dont forget to mark as solution if your question is answered
Note: My advice is amateur help/beginner troubleshooting, someone else can probably troubleshoot way better than me.
- I do have some experience, and I can use google pretty well. - Feel free to quote me I may respond soon.
Join team Red, my apprentice
STOP SIDING WITH NVIDEA
Setup:
Ryzen 7 5700X / ASRock Challenger RX 6750 XT PRO OC 12GB / ROG STRIX B550-F Gaming / Be Quiet! Pure Rock 2 FX CPU Cooler / Be Quiet! 750 Watt 80 PLUS Gold PSU / Sharkoon TK5M Case / 4x16 GB Kingston FURY RAM / 2x 1TB FireCuda BESKAR Edition / 3x iiYama 1440p 165HZ Montitor / Shure MV7 / GK61 Keyboard / Logitech G502-X Mouse
1 hour ago, Gokul_P said:
All of your fans spin and what is this case
Yes all my spin my case is sharkon dg7000
36 minutes ago, Blqckout said:
thats pretty normal
For strix 4090 is normal?
If this is the case you are talking about I doubt this can handle Both 13900K and 4090 at full tilt. and how about your cpu temps (This kind of design cant even handle 9700F and 1650 Oc from my experiance but it only had 1 front fan)
Yes is my case my 13900k overclock to 5.6 p-core and 45 e-core in r23 my cpu temp is 92c and games 70-80c i have 6 fan in my case
I think you should invest in a high airflow case both of your Components is extreamly powerful So you need extreamly good airflow in order to Air cool those two. Tbh The best think for this components will be custom loop
you right this Components drow a lot of power and heat but my question is why the gpu is hotter by 5c then last month and my room temp is the same also my hot spot is hotter
5C it is prob a messuring issue or a driver update that potentially using the gpu more or dust build up (but i doubt that)
 Share
