ALERT - Linus Tech Tips, Tech Quickie, Tech Linked Youtube Channels Hacked ×
Help, audio Pc new build having tons of latency issues
Hi everyone, I just finished building my new audio pc. Unfortunately, i have encountered tons of issues with it, at first I thought it was becasue of my sample rate and also the quality of audio which was 4800khz but decided to unplug my audio interface and connect straight to the monitor with the hdmi cable, and im still seeing dpc spikes so now im sure its not the audio monitor or software since this spikes happen with youtube and without playing any audio. The build is as follows :
i7 12700k
asus z690-f
corsaire vengace ddr5 5200 32gb
wd sn850x m.2 nvme 2tb
crucial m.2 sata in the port m_4 of the motherboard
1 970 ssd samsung
1 hdd from an old apple computer.
audio interface is Komplete audio 6 km1
by the way running windows 10 on high performance.
i used process lasso to put the audiodgx.exe to core sets 0,2,4,6,8...etc and priority high, as well as NKi6.exe to those same cores and priority high.
Latest BIOS?
https://rog.asus.com/motherboards/rog-strix/rog-strix-z690-f-gaming-wifi-model/helpdesk_bios/
Also, check the firmwares under Firmware.
PD reffers to USB Power Delivery. It affects USB devices.
  • Main PC: AMD Ryzen 9 5900X - EK AIO 360 D-RGB - Arctic Cooling MX-4 - Asus Prime X570-P - 4x8GB DDR4 3200 HyperX Fury CL16 - Sapphire Pulse Radeon  RX 5700XT - 1TB Kingston Fury Renegade - 1TB ADATA SX 6000pro  - 512GB ADATA SU800 - 1TB Seagate Momentus 5400rpm 2.5" - SAMA Armor Gold 750W  - custom black ATX and EPS cables - Fractal Design Define R5 Blackout - Windows 11 x64 2022 - 3 Arctic Cooling P14 PWM PST - 2 Arctic Cooling P12 PWM PST
  • Peripherals: LG 32GK650F - Philips 226VL - Logitech G Pro X Superlight - White Shark Spartan X (TKL) - EndGame Gear MPC890 - Genius HF 1250B - Asus Xonar U5 - Sennheiser HD 560s - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Laptop: Acer E5–575G-386R 15.6" 1080p (i3 6100U + 2x4GB DDR4 + GeForce 940MX + 256GB nVME) Win 10 Pro x64 22H1 - Logitech G305 + AAA Lithium battery
  • Networking: Asus RT-N18U - SpeedPort Plus - 35/7 Mbps vDSL - TP-Link TL-WA850RE - TP-Link 5-port 1Gbps switch
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS - Samsung Galaxy Tab A8 10.1" - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color
  • Streaming/Server/Storage PC: AMD Ryzen 5 3600 - LC-Power LC-CC-120 - MSI B450 Tomahawk Max - 2x4GB ADATA 2666 DDR4 - 120GB Kingston V300 - Toshiba DT01ACA100 1TB - Toshiba DT01ACA200 2TB - 2x WD Green 2TB - Sapphire Pulse AMD Radeon R9 380X 4GB - 550W EVGA G3 SuperNova - Chieftec Giga DF-01B - Logitech G710+ - Roccat Kone Pure Military Desert strike - Logitech S-220
Hi yes, latets bios and drivers. and also latest firmwares. looks like firmware version is 0003 at least with the asus toolmotherboard.thumb.jpg.f9597e8562bbb81a93c9c6e6b8b5229d.jpg
Hm wait latest version of pd was 0006 updated now and checking again
Running the test on idle again for 10 min seeing if there is another spike after updated pd version
Ok dont want to  jinx it but so far I have had some issues only with the audio interfance not with latencymon. This requires further testing but so far it seems that the
PD reffers to USB Power Delivery. It affects USB devices. driver might have worked. since Even though i had armoury crate and installed all the drivers it didnt install the latest one
Perhaps i spoke too soon i got one crash again, although i was getting them every like 5-6 mins now it took like 20 plus
 Share
