Why not just neatly tie up what you don't need and cable tie it? That's what I do.
I second that, tying them up is faster and cheaper
CPU: Intel core i5 3570 Motherboard: Gigabyte-H77-DS3H Case: Fractal Design Define R4 Storage: Seagate Barracuda 2TB  GPU: MSI Radeon HD 7950 Twin Frozr III Cooler: CM Hyper 212 Evo RAM: Crucial Ballistix Sport 16GB  PSU: Seasonic G Series 550W
Acer Aspire S7 Overview Sennheiser PC360
https://linustechtips.com/topic/148552-headphone-wire-too-long/#findComment-1984164
Have you considered the cheapest option?
Is it XLR or just a plain 3.5mm plug? As long as the cable you find to replace is good quality you should be fine.
CORSAIR RIPPER: AMD 3970X - 3080TI & 2080TI - 64GB Ram - 2.5TB NVME SSD's - 35" G-Sync 120hz 1440P
MFB (Mining/Folding/Boinc): AMD 1600 - 3080 & 1080Ti - 16GB Ram - 240GB SSD
Dell OPTIPLEX:  Intel i5 6500 - 8GB Ram - 256GB SSD
PC & CONSOLE GAMER
https://linustechtips.com/topic/148552-headphone-wire-too-long/#findComment-1984167
I think the HD 5xx series uses a 2.5mm plug on the headphone side. If you can find one that fits it shouldn't degrade audio but the problem is finding a wire that will fit.
https://linustechtips.com/topic/148552-headphone-wire-too-long/#findComment-1984360
