First PC Build
Solved by Aaron_T,
There isn't much difference in the board partner card's performance. If it were me, I'd probably get a bit cheaper 3070 like a Zotac or Gigabyte model, then use the cash to get a 1440p high refresh rate monitor in stead of 1080p, because a 3070 is going to handle 1440p resolution just fine in most cases.
Another thought you might also consider. At the $3k price point you may be able to squeeze a current gen platform into the build, like a 7600x, AM5 board and DDR5.
