help
Solved by nont3ro_169hz,
20 minutes ago, johnno23 said:purchased last year with a CPU from April 2012 ??? almost 13 years old already.
for starters just unistall anything you do not use would be the best start. Check your system for apps that run in the background and disable anything you do not need.
lots of online articles that give information and advice on what can be safely removed or disabled.
you simply have to reduce the load on your CPU and Graphics as your system is probably getting overwhelmed whe you launch a game.
Okay thank,but maybe you can help me with that?
