As in if you went say PC - wattage meter - UPS - wall? No. However if you went PC - UPS - wattage meter - wall, then yes there will be a slight difference because the UPS is consuming power for the LCD display amongst other things.
https://linustechtips.com/topic/14845-ups/#findComment-165857
