Budget (including currency): Roughly 2500 USD / 17.000 DKK
Country:  Denmark
Games, programs or workloads that it will be used for: Gaming in general
Other details My current planned build: https://pcpartpicker.com/list/pT82C6
Can anyone let me know if the pcpartpicker build i linked above is alright, or if i need to / should change anything?
https://linustechtips.com/topic/1484011-building-my-first-pc/
Looks decent,
the CPU cooler could be better, by the very least a Noctua with 2 fans instead of 1
also things like, does the new case need fans or does it have it's own?
Another thing I'm not sure of is the 5400RPM HDD.
@PDifolco
current PC:
PC configs I used before:
https://linustechtips.com/topic/1484011-building-my-first-pc/#findComment-15769611
Supposing you need a high capacity HDD I let the 5400 HDD...
I don't like much the 7600, only 6 cores, it's meh compared to a 13600K... So I'd get at least a 7700
Then you could get a better board, cheaper cooler, and cheaper fans (and even more of them 🙂 )
In Europe the 7900XT is badly (over)priced, imo the 4070Ti is overall preferable
And I like Phanteks cases 🙂
PCPartPicker Part List
CPU: AMD Ryzen 7 7700 3.6 GHz 8-Core Processor  (2842.00kr @ Alternate)
CPU Cooler: Deepcool AK620 68.99 CFM CPU Cooler  (578.00kr @ Proshop)
Motherboard: Gigabyte B650 AORUS ELITE AX ATX AM5 Motherboard  (2054.00kr @ Alternate)
Memory: G.Skill Flare X5 32 GB (2 x 16 GB) DDR5-6000 CL36 Memory  (1291.00kr @ Alternate)
Storage: Samsung 970 Evo Plus 1 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  (968.00kr @ Dustin Home)
Storage: Seagate BarraCuda 4 TB 3.5" 5400 RPM Internal Hard Drive  (645.00kr @ Proshop)
Video Card: Zotac GAMING Trinity GeForce RTX 4070 Ti 12 GB Video Card  (7013.00kr @ Alternate)
Case: Phanteks Eclipse G360A ATX Mid Tower Case  (838.00kr @ Proshop)
Power Supply: Corsair RM750x (2021) 750 W 80+ Gold Certified Fully Modular ATX Power Supply  (1367.00kr @ Alternate)
Case Fan: ARCTIC P14 PST 72.8 CFM 140 mm Fans 5-Pack  (284.00kr @ Proshop)
Total: 17880.00kr
Generated by PCPartPicker 2023-01-26 14:37 CET+0100
https://linustechtips.com/topic/1484011-building-my-first-pc/#findComment-15769636
If the HDD is for data backup, that's fine. If you need a secondary game, especially since gaming uses up a lot of storage, get a second ssd to install games to, too, but don't use the HDD as a secondary drive.
When it comes to cases, how it looks isn't important; whether it provides great ventilation options and can hold everything you want is. If you're planning to get a hot swap or dvd/Bluray, make sure there is an actual bay for that or you'll be forced to buy external drives.
I've been using computers since around 1978, started learning programming in 1980 on Apple IIs, started learning about hardware in 1990, ran a BBS from 1990-95, built my first Windows PC around 2000, taught myself malware removal starting in 2005 (also learned on Bleeping Computer), learned web dev starting in 2017, and I think I can fill a thimble with all that knowledge. 😉 I'm not an expert, which is why I keep investigating the answers that others give to try and improve my knowledge, so feel free to double-check the advice I give.
My phone's auto-correct is named Otto Rong.🤪😂
https://linustechtips.com/topic/1484011-building-my-first-pc/#findComment-15769639
