12 volt only for small build
Solved by BobVonBob,
The 8 pin connector is the same as the EPS 8 pin power connector that would go to the CPU in an ATX system. You don't need an adapter for it. All you need is the 24 pin to 4 pin adapter, which is included with the motherboard.
Edit: In fact, that's not even a 12VO board. ATX12VO uses 10 and 6 pin connectors. That's just a normal CPU EPS connector and a 4 pin connector for those standby and power on signals.
