I have an old Dell laptop lying around, and whenever I keep it on charging, the touchpad gets extremely inaccurate, until I remove the adapter. Does anybody face this same issue on older laptops and is there a way to fix it?
PLEASE MARK COMMENTS AS SOLUTION IF SATISFIED!!
bigger number better, makes me look cooler.
https://linustechtips.com/topic/1483550-touchpad-going-crazy-when-charging/
Have you tried to use a grounded outlet?
Gaming PC:
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: Crucial 2x16gb, 3200  JEDEC. | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Asus Prime RTX 5070ti OC| Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: Kingston Renegade 2TB and Corsair MP510 960gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
Linux PC:
CPU: Ryzen 7700| Motherboard: Asus A620M-CSM | RAM: Crucial Pro 2x48gb, 5600  JEDEC. | PSU: Corsair CX750 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: MSI Gaming X RTX 3090 | Case: Lian Li Dan Cases A3-mATX black |Storage: SN7100 2TB + Samsung 860 EVO 512gb | Cooling: CPU: Thermalright Peerless Assassin Mini Fan(s): Noctua 1x NF-A14x25 Chromax
stupid question, but does a USB mouse work?
Yes, a stupid question indeed. Mouse works but the existence of a touchpad on a laptop matters.
@DoctorNick@Tom_nerd@powertoys
I have heard that is sometimes happens in older laptops and in mobile phones too because the touchpad/touchscreen is located right above the battery, and the battery while charging can interfere with the touchpad/touchscreen. So....
Yes and therefore you must ground the PSU 🙂 https://en.wikipedia.org/wiki/Ground_(electricity)
Gaming PC:
Linux PC:
tldr. What do i do then?
Ungrounded versus Grounded Outlets - Canadian Home Inspection Services
Hope this makes sense. Check if your adapter has 3 legs, if yes, use a grounded outlet (where you plugin the power supply in the wall)
Gaming PC:
Linux PC:
3 hours ago, NvidiaFirePro6900XXTX3DPRO said:
@DoctorNickYes I do have 3 pins, and I already to plug in the connector into the wall directly.
ok but the wall outlet isn't grounded then 🙂
Gaming PC:
Linux PC:
