please help me im a beginner
Go to solution Solved by Fasauceome,
16 hours ago, DGG_Peacemaker said:
but i dont know what is compatible
Please quote us so we can see your responses
The built in compatibility checker on PCPartPicker.com is useful for making sure that your CPU and motherboard are compatible.
On 1/22/2023 at 7:41 PM, DGG_Peacemaker said:
Budget (including currency): as chaeap as it goes but still good performance
"As cheap as possible but still good" can mean different things to different people. But, for someone upgrading from an old FX CPU, I recommend:
1) A cheap Ryzen 5 2600 or 1600-AF from eBay
2) a cheap used or new B450 motherboard (with a decent heat sink on the vrm)
3) the cheapest DDR4 3000 or 3200 you can get.
With this, you can save a lot of money and get a very good upgrade path.
1792128389_linus.thumb.png.21d92f17e71bf014df90fb26fdfe29c4.pngBudget (including currency): as chaeap as it goes but still good performance
Country: germany
Games, programs or workloads that it will be used for: escape from tarkov and other games
so my current system
MAINBOARD : ASUSTeK COMPUTER INC. M5A97 LE R2.0
CPU               : AMD FX(tm).8350 Eight-Core Processor, 4000 MHz, 4 cores (8 logic processors)
GPU               :NVIDIA GeForce GTX 1060  3GB
i am a absolute noob when it comes to a PC so i hope someone can help me. im looking foward to uprade my PC but dont have a clue what im doing.im having variouse problems with my pc now like KERNELL MODE HEAP CORRUPTION or WHEA UNCORRECTABLE ERROR and dont know what do do besides uprading parts my main goal is to get a game very good running its called Escape from Tarkov and its very demanding on my pc so i can only play it on very low settings help is apreciated
https://linustechtips.com/topic/1483263-please-help-me-im-a-beginner/
Check out mindfactory. That's the largest store in Germany. That way you know what is available to you, like cases. For help with cases you should preselect a bit since those are very subjective.
 Best to use pcpartspicker. That also checks compatibility.
No signature
Primary PC:
PSU tier list
How many watts do I need?
