If my 360 mm radiator for my CPU is in the front pulling in air, and my rear fan is exhausting air, should I also have two additional fans at the top of the case, would they do anything? I have them installed right now but they aren't active as I don't know the best direction, intake or exhaust.
https://linustechtips.com/topic/1482848-fan-direction-help/
@MarkAnthony121
Yes, ideally you should have two or three pulling in in the front, and two or three topside / rear blowing out / up for exhaust. Some cases are the exception to the rule, but that doesn't appear to be one of them.
I don't badmouth others' input, I'd appreciate others not badmouthing mine. *** More below ***
MODERATE TO SEVERE AUTISTIC, COMPLICATED WITH COVID FOG
Due to the above, I've likely revised posts <30 min old, and do not think as you do.
THINK BEFORE YOU REPLY!
https://linustechtips.com/topic/1482848-fan-direction-help/#findComment-15761285
3 minutes ago, An0maly_76 said:
@MarkAnthony121
Thanks I appreciate it!
https://linustechtips.com/topic/1482848-fan-direction-help/#findComment-15761289
1 hour ago, MarkAnthony121 said:
Top exhausting seems to be the way to go 🙂
Yup, I have 2 140mm intake on front, two 140mm exhaust on top, and 1 120mm exhaust in the back (that I don’t suspect does much given the position of my pc to the wall) in my machine.
My PC Specs: (expand to view)
Main Gaming Machine
CPU:  Intel Core i7-14700K
CPU Cooler: Deepcool LT720
Motherboard: MSI PRO Z790-P WIFI
Memory: G.Skill Trident Z5 RGB 32 GB (2 x 16 GB) DDR5-6400
Storage 1: Samsung 990 Pro 2 TB
Storage 2: Crucial P3 Plus 4 TB
Video Card: EVGA XC3 ULTRA GAMING GeForce RTX 3080 10GB
Power Supply: Corsair RM850 850W
Case: Corsair 7000D Airflow
Case Fan 140mm: Noctua A14 PWM 82.5 CFM 140 mm (x7)
Monitor Main: MSI G274QPF-QD 27.0" 2560 x 1440 170 Hz
Monitor Vertical: Asus VA27EHE 27.0" 1920x1080 75 Hz
https://linustechtips.com/topic/1482848-fan-direction-help/#findComment-15761343
  • 2 weeks later...
Very good point. After I just made a small upgrade I put my pc back on my desk but not fully against the wall while I tested it to make sure it worked (then I was gonna position it perfectly pushed back). But I noticed, oh yea, this rear exhaust actually works now that it isn't 3 inches against a wall! lol
https://linustechtips.com/topic/1482848-fan-direction-help/#findComment-15780023
