Micro (or mini) ITX Build
Go to solution Solved by DirtyBirdX,
23 hours ago, Kinda Bottlenecked said:
PCPartPicker Part List: https://pcpartpicker.com/list/nsnnv3
CPU: AMD Ryzen 7 5800X3D 3.4 GHz 8-Core Processor  ($338.98 @ Amazon)
Motherboard: Gigabyte B550M DS3H AC Micro ATX AM4 Motherboard  ($109.99 @ Newegg)
Memory: Silicon Power GAMING 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  ($39.97 @ Amazon)
Storage: Silicon Power A60 1 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  ($52.49 @ Newegg Sellers)
Video Card: Zotac GAMING Trinity GeForce RTX 4070 Ti 12 GB Video Card  ($799.99 @ B&H)
Case: SAMA IM01 MicroATX Mini Tower Case
Power Supply: Cooler Master V850 SFX GOLD 850 W 80+ Gold Certified Fully Modular SFX Power Supply  ($144.00 @ B&H)
Total: $1485.42
Generated by PCPartPicker 2023-01-20 06:09 EST-0500
This bad boy will run everything.
PCPartPicker Part List: https://pcpartpicker.com/list/nwm8Bj
CPU: AMD Ryzen 5 5500 3.6 GHz 6-Core Processor  ($97.99 @ Newegg)
Motherboard: Gigabyte A520I AC Mini ITX AM4 Motherboard  ($119.99 @ Amazon)
Video Card: ASRock Challenger D Radeon RX 6600 8 GB Video Card  ($234.99 @ Newegg)
Case: Lian Li Q58 (PCIe 3.0) Mini ITX Desktop Case  ($79.99 @ Newegg Sellers)
Power Supply: Cooler Master V650 SFX GOLD 650 W 80+ Gold Certified Fully Modular SFX Power Supply  ($104.99 @ Newegg)
Total: $730.41
Generated by PCPartPicker 2023-01-20 06:20 EST-0500
This bad boy will run most things.
Awesome I appreciate your help!
I am trying to put together a mini/ micro itx build that will be used for my living room tv and my game room tv. It doesn't need to be an overly powerful gaming pc, just enough to play those random split screen games with friends and stream movies.
I am looking to build a couple and want them to be small enough to not be an eye sore in open spaces.
I'm located on the East coast and have a Micro Center near me.
I am hoping to keep it under 1500 USD if not lower.
The storage doesn't need to be crazy, at max being 1tb and NVME isn't a necessity either unless it fits the budget.
No more than 60 fps is needed as the tv's don't run any faster than 60hz (with my current TV's). And obviously since I am trying to keep cost down I am not to worries about 4k or even 1440p.
Any help on what parts/ components would work best would be much appreciated!
https://linustechtips.com/topic/1482638-micro-or-mini-itx-build/
Total: $1485.42
Total: $730.41
i5 2400 | ASUS RTX 4090 TUF OC | Seasonic 1200W Prime Gold | WD Green 120gb | WD Blue 1tb | some ram | a random case
Total: $730.41
I would go with this, it should do what OP outlined no problem
Trans Rights!
Please tag me or use the "reply" function so I get a notification
I will find your Laptop thread and I will recommend an ITX build instead
Sure would be neat if there was something useful here, eh?
Total: $1485.42
Total: $730.41
