Horizontal or Vertical help.
Go to solution Solved by PopsicleHustler,
3 minutes ago, s0mersbybg_ said:
Also, soon as possible i will buy a new 120mm 2x fans for TOP and one more for LEFT
Don't go overboard with top exhaust fans. I learned the hard way that it chokes the CPU cooler to death. I have x2 120mm top exhaust and x1 120mm rear exhaust. Had to put top exhausts to minimum RPM in order to balance out the pressure and air movement throughout the case which is Meshify C
I assume you're talking about your tower CPU cooler? The way its installed in the picture is ideal. It gets fresh air from the intakes rather than a lovely toasty breeze from the GPU
Main system: Ryzen 7 7800X3D / Asus TUF Gaming B650-Plus / G.Skill Trident Z5 NEO 32GB 6000Mhz / Zotac RTX 5090 SOLID OC/ x2 WD_BLACK NS770 2TBs/ Corsair HX1000i/ NZXT H5 Flow
